Hi all
I have an Myson Apollo 30B Boiler system. I have just replaced the Water Pump on my heating system after it has been firing up, boiling the water and then shutting down. This has solved this problem but now the controller unit is not responding when I turn the dial or when I change it to OFF on the HW/CH - HW switch (it stays fired up). It does repond to Hi and Lo - firing up normally. I suspect a I need a new controller but when the boiler is fired up on High a strange loud clicking sound comes from the Gas valve cover.
Any Ideas?
And will the Honeywell ST6200A controller work with my setup?
Any Ideas?
