Hi All,
Seen a few topics here about this but can't seem to find one for my particular issue.
I have a problem with the boiler in that it is losing pressure and there is a drip on the release pipe on the outside. I check the pressure vessell and there is no air in it. So I drain the system down using the drain cock and use a electrical pump with a digital pressure gauge to pump it up after pumping for a bit I drain the extra water out of the boiler until nothing comes out and keep pumping. I set the pump to stop at 1PSI but the pump goes for about 4 minutes and can't see the pressure gauge going up on it so I stopped since this pump can inflate a car tire in 3 minutes, when I press the valve on the boiler air comes out. I know the pressure gauge is working since when I put it on a car tire it works fine. I think the pressure vessel is fine since no water comes out. Any other ideas as to what could be wrong? Thanks
