- Joined
- 2 Feb 2014
- Messages
- 412
- Reaction score
- 2
- Country
I've put 2 sets of doors back on after filling in the screw holes & there's another 2 to go.
Problem is i can't find the remaining screws. We have a box of screws, same thickness & length as the others i've used but with different heads (pozi instead of flat that i'd been using).
Problem is i tried drilling these home & the bit just keeps spinning. I tried by hand & it's a no-go. The bit is as big as the head will allow so i assume the right one & it's a pozi bit.
Why would this be? Could it be down to the pilot holes being quite small? I didn't want to drill in the holes too big so i kept it to a thin hole.
Also when screwing on interior doors, should you get the beefiest screw the hinge & frame will allow or would thinner screws be fine?
