I'm trying to get my kitchen mixer tap tightened, as the body of the tap is loose and twists when I use the hot/cold taps.
It looks to be attached to the s/steel drainer with a single brass nut. Problem is, there's no horizontal space around the nut so I can't get a spanner in there.
I've prettymuch only got vertical access from directly beneath the nut. Any ideas what I need to do get this tightened up? Is there a special tool for this?
