I have a problem with my hot water, when I switch the water on the pilot light comes on then goes off again and the water wont heat up, but it heats up ok if I put the heating on as well but not on its own.
I had my boiler serviced and the engineer said that there was a problem with my Actuator, he said there was not enough volts going through it to keep it on and it needed to be replaced. Do I need to replace the whole Actuator or is there a part inside it that can be replaced.
And where can I buy the correct parts.
It is a British Gas valve code BGMVSP-2
Any help would be appricated.
