We've just decommissioned the boiler elements of our alpha cooker and replaced it with a traditional CD boiler. Central heating is working fine, all controlled by the same 3-zone controller that used to control the CH and hot water from the alpha.
Came to use the cooker for the first time and ran it for about 2 hours at 150 degrees until the high limit stat kicked in - which takes out the controller.
I had the boiler thermostat on the alpha boiler control set to zero, but there is no power getting to those circuits in the alpha. When I turned the alpha thermostat to max (85). I cranked the cooker up to 240. It reached the temperature,. but shortly after, the high stat kicked in again.
Is this a coincidence and I have a problem with the cooker thermostat or have I created a major problem by decommisioning the boiler elements of the alpha?
I suspect (hope) it's a coincidence as the installation instructions for the cooker shows a circuit diagram for a 'dry cooker' - ie no CH boiler working.
Any advice would be truly appreciated
cheers Mike
cheers Mike
