Problem with Baxi 80 Eco not firing
6 Oct 2004
Hi there
Baxi 80Eco installed pre christmas. We had to turn off electrics to modify the circuit elsewhere yesterday.
This afternoon I notice no hot water. I go to the boiler with the DHW tap on, and the only light is the power light. Burner on neon does not light, nor does flame failure neon. Similar when I put the CH to on.
I cna hear the pump working, but no flame!
What can I do to try and resolve it myself, or is it a call to Baxi under warranty? Or do I call the people who installed it under warranty?
Many thanks.
Just confirmed that the boiler was working this afternoon, so has definately worked since yesterday's power off.
Even more puzzling. Help ! :cry:
Inside the boiler a quarter way up near the back on a 22mm pipe is a overheat stat with a very small black or red button in the middle of it.Push the button and HEY PRESTO. :D
the lockout can be caused but drawing long amounts of hw off at a slow rate, there is a fix for this now, which stops the boiler locking out whilst the burner is off. if it dose lock out whilst the burner is on due to an overheat, it can be reset from the front.....is the boiler still in waranty???
Hopefully the o/h stat will be the cause, if not there are other possibilities.
Generally if you had a quality installer they will come out at no charge if you have any problems for at least a year. Make sure first that you have kept the pressure topped up at about 1.5 Bar and all the switches are on.
If you call the manufacturer and they find the problem is due to debris in the system because it was not properly powerflushed and chemically treated then it is likely to be a chargeable call!
Tony Glazier
WHat needs changing, to make that mod, Jason?
Brilliant, thank you so much for this. Did the trick as advised.
What is the cause of this problem, if it is a common solution, why tuck the button away where most consumers would have no idea?
Thanks again, and to everybody for the lightning fast replies. Is there any advice to prevent it happening again?
chrisr send me your email, and i will forward instructions, dont want to post on here, cause i ca see some diyer bodging it and looping out oh stats.
the new kit makes it so the customer can reset it.....
Soz hijacking post but just want to ask jason a question .Have you come across any 80e`s or 105e`s that make quite a loud droning noise coming from boiler for first five mins on start up from cold only on heating hot water is perfect and not a sound . Pressures are correct and system is clean and inhibited .and after initial noise boiler runs as quiet as mouse. thanks
