I am in the process of trying to finalise plans on building a house extension.
My problem is that one wall will be situated about 3-4 inches from my neighbours wooden garage. After long negotiations my neighbour has refused to move the garage or dismantle one side of it allowing me to build from inside it.
This apparently causes massive problems................
The original plans were for the extension to be a kit house however clearly it wont be possible to put up a kit and build from the inside. Then there is the issue of waterproofing the wall with a roughcast finish as this wont be possible with the garage in the way.
My architect suggests building with Fyfestone as a means to keeping the elements out and instead of it being a kit house I would need to do a traditional build and build from the inside of the extension. My builder is refusing to build with Fyfestone as he says he wont be able to 'key it' which I presume is the finish required for Fyfestone.
Does anyone have an suggestions as to how I can build this wall with the garage next to it?
Many Thanks
Craig
Many Thanks
Craig
