Hoping someone can help me here.
I have got a new light and a dimmer switch for my son’s bedroom.
I fitted the dimmer switch fine and it was working.
I then moved onto fitting his new ceiling light, only problem is it keeps tripping out the 5v fuse.
If I have the light upstairs turned on while I turn the mains power on the light will light up fine. But if I use the switch to turn this off it trips the fuse. It will also trip the fuse if I turn on mains power when the light switch is on the off position.
Any idea why this is happening?
I tried changing the back from the dimmer switch to the old normal switch but no luck.
I was thinking possibly I need a new low voltage light switch but thought id would seek advice before going out to buy another one.
Thanks,
S~
Thanks,
S~
