Hi Guys,
I had by Baxi boiler installed and they used a Center EHE0200361 RF Programmable room Thermostat in April 2016, the problem is that it displays the wrong temperature, my wife got up at 3 AM to go to the loo and had a look at it and it said that it was 19 degrees, there was no way that it was anywhere near that, we've also compared it with a normal thermometer and it reads high, is there anything I can do or does it need replacing?
I used to work on computers and a common thing was over heating, especially laptops, they just clog up with dust, is it the same with these? Can I take it apart and clean it? I'm guessing there is some kind of temperature probe or something, does that need a wipe over?
I've Googled 'Center EHE0200361' and it tells me that Amazon sell them for around £230, that seems like a lot of money for a controller.
If I do need to replace it, do I need to replace the 'Relay' in the loft.
I have gone through the 'Binding process just in case, at the moment no difference.
If it makes any difference, the boiler is in the loft, the RF Room thermostat is in the hall, probably 12 ft away
Many Thanks,
Steve
Many Thanks,
Steve
