Hi, I was wondering if someone could help please...
Although my central heating clock appears to be OK with all the lights lighting up the correct way my boiler is not igniting, there is also no noise or vibration on the solenoid on the boiler. I've had a problem with the Honeywell ST6400C clock before but solved it by cleaning the tracks on the circuit board inside it, but this time to no avail.
I suspect a problem with the clock but does anyone know what I should be metering at the solenoid end? Thanks in advance.
