Hi There,
The filling loop has been left connected to my boiler by the previous occupants and I would like to disconnect one end of it in order to avoid 'accidental' pressurising of the system, and also to comply with regs.
So, what I have done is ensure that isolation valve on filling loop (mains water side) is closed and then disconnected other end of hose via wing nut coupling. However, when I did this water was coming out at a fair rate so I quickly reconnected it again. I was wondering whether the isolation valve on mains water end of filling loop is shutting off properly? When I close the valve with an adjustable spanner (the black lever part is missing) it certainly appears to be turned fully and won't go any further.
Also, I recently had a leak in a radiator pipe that caused a complete loss of boiler pressure. I had this repaired by a heating engineer, who then repressurised the system to 1 bar. He stayed for a short while to ensure that pressure stayed at 1bar and then left. However, when I looked a week later the pressure gauge was reading around 2 bar. My first thought is that perhaps the filling loop isn't completely closed but it did take a long time to increase from 1 to 2 bar so not sure.
Any thoughts on this would be most appreciated. Any suggestions on what I should check also greatly appreciated.
As my name suggests, I am a qualified engineer but of the electronics variety so my plumbing skills are somewhat limited!
Cheers.
Cheers.
