Problem with glowworm cxi24
30 Nov 2014
Lancashire
hi everyone..
could anyone help with my glowworm cxi24.
my problem is with I think with build in thermostat or electronic system.
what is happening...when I choose programme lets say 45 degrees for 3 hours, system automatically leaving the program after 1,2 minutes and start heating on full power over 70 degrees.
I've try to reset already even unplug the boiler for 24hours. nothing help
don't know what could goes wrong if someone could help with this problem
I've got this boiler for 6years installed by corgi inst.
thank
You cant programme how hot the boiler runs, that can only be adjusted with the dials on the front of the boiler.
Where are you "programming" it?
Would help to avoid confusion by adding "C" after any temperature to confirm which units you are using.
Putting your location in your profile would also help us too.
Tony
basically its not stick to to the program. I want to run boiler for few hours and the hes gonna exit the program but in my case hes leaving program straight away
