I have a concealed cistern with a Grohe dual flush 42314 (what I'll call the unit in the description below!). I had to remove the unit to refit the small air tube that attached to the flush button (it came off and wouldn't flush) and ever since I've been unable to stop the steady trickle of water into the pan. Not much, but enough to be noticeable in the bowl.
The Grohe unit itself seems to just rest in the inlet to the pan at the bottom of the cistern. It doesn't screw in or fix itself in any way, meaning that occasionally it just unseats itself. The large washer around the bottom looks okay but I can't get it to seat so that there's no trickle. It was fine before I removed it so I know it's probably something I've done. I just don't know whether I'm missing something.
As you've probably guessed, I'm no plumber, so any guidance would be much appreciated.
Thanks,
Chris.
Thanks,
Chris.
