i have an issue with my communal lights in a hallway in my house. There are 7 x 50w GU10 spotlights 240v . 2 days ago the lights went out and will not relight. This has not tripped any MCB`s or RCD (as it is a 17th edition consumer unit). There are 4 switches in total in the circuit. 2 x 2way and 2 x intermediate light switches outside of the bedrooms. I have used a digital multimeter to test the switches and they are fine. switching correctly and since the house was only re-wired last year (by myself) i know that there is no issue there. I have removed all lamps from the spotlights and tested the connections at the lampholder choc blocks and i am reading 170v L-N and 230v L-E. when testing the switch side i am reading 230v L(feed)-E and also 230v L(switch) so i dont think it is breaking down on the switch end.
a full inspection was done 4-5 months ago and passed with flying colours but i know it is only as good as an M.O.T
I have also tried to plug the lamps that aren't working into a proven circuit on the same level and they are working
so i am still stumped as to why the lights wont work. They do glow for a fraction of a second but then do not start up at all.
i have had issues before with bad lamps and replaced the lamps bringing all the lights back on.
could it be contact deteriation? (they have been in less than a yr)
any ideas?
any ideas?
