Problem with Ideal Icos
5 Jul 2005
Sussex
I have just fitted an Ideal Icos 18HE boiler, when the boiler lights up it goes with an explosion when the main burner lights.
Any ideas?
beermat. was it you who fitted the boiler or someone else. are you corgi registered??
this boiler sounds like it was not commisioned and needs set up.
why do I get the impression your having a laugh marra.
boiler needs an engineer to commission it
Yes I am corgi regesitered, I have check the gas pressure which is what I though the problem might, be. It was fine, but there is no way of altering it anyway is there?
some education then marra that nice little number aint worth JS
if you did the job by the book get the b*ggers out to sort it
their problem
I have had this with 3 I fitted this year. On all of them it was the ignition lead not pushed in tight onto the ignition probe.
Black rubber connection to the right of the heat exch.
