OK, I know it's a cheap system but I don't want to replace it until I have my extension done, so I have to live with it for a while.
Basically the problem occurs after a power cut (which unfortunately seems not uncommon where I live).
The battery takes over OK, but the alarm goes into a non-responsive mode. The keypads are active, but none of the codes work. I just press the keys and get the backlight and beeping, but nothing happens. This stays like this when the power is restored.
To solve the problem I need to do a hard reset (power off the alarm system and disconnect the battery). Then I can bring it back into operation using the engineering code.
Anyone know if this is a 'known' issue with a solution?
