a few years ago we got re-wired by the council and an isolator was put in by the REC. i have just been in the cupboard busy with the CU (adding a spur) when i noticed a hole in the cover over the isolator. took the cover off and there was also previously melted plastic on the neutral tail to the CU. loosened the screw (was in very tight) but couldnt get the wire out to look at any damage. the screw also didnt come out smoothly (as tho it had corroded)
what should i do bout it, since its possible the main isolator is damaged? call the REC?
