I have just installed a new kitchen at home, I have just put in the monobloc 1/4 turn tap on 15mm pipe work with flexi hose connectors.
When I have opened the isolater valves, the cold water runs non stop and doesnt go off or increase in pressure when the tap is turned, its just a constant blast.
The hot water responds to being turned on/off but is only trickling out.
I have the washing machine plumbed in less than a metre away and the pressures are fine in hot and cold as I have tested this with the hoses disconnected from the back of the machine, and also the bathroom upstairs taps are working as normal.
I am not using a combi system, just a hot water cylinder and cold water storage.
Any help would be appreciated.
Thanks Richie.
Thanks Richie.
