We have just brought a new house built in the late 1800s. I wanted to repaint the hallway white.
There is a decorative trim that runs halfway up the wall. above the trim is painted white. Below the trim is grey wallpaper. I decided that I wanted to remove the weallpaper and paint this white.
However, when I started removing the wallpaper the wall beneath is brown. At first glance it almost looked like wood as it had a slight grainy look to it. The brown surface is smooth to the touch.
I used a steamer to remove the rest of the wallpaper. Some of the brown stuf did come off when steamed for ages and scraped a lot but underneath this is the plaster and it is very rough and almost chalky in texture.
What do I do? Should I persevere and remove the brown stuff and skim the wall..
I can post images if this will help
