I have just had the front of a new extension rendered and there is a problem with cracks appearing as it cures.
The build is using a solid thermal block wall (215mm thick) and an intial scratch coat was applied to the front and sides. This was left to cure for a few days then a top coat applied to the front on Thursday.
When the renderer came back on Friday morning, the top coat on the front of the house had started to craze in places with small veins appearing (mosaic like appearance) - the porch was OK.
Yesterday, the front had dried out further and the veins were now cracks and the porch has dried out further and the veins are appearing.
The render was applied using the mix recommended by the block manufacturer (6:1 sand/cement with plasticiser for the scratch and 6:1:1 sand/cement/lime) for the top coat.
The renderer decided to not top coat the rest of the building until we find out what has caused this problem. The block manufacturer suggested using a coarser sand (the sand originally used was building sand).
The render, although cracked, does not seem to have blown off the blocks - but it has not fully cured yet.
Has anyone experienced this type of problem before, particularly on thermal block?
I'd be interested in any comments or suggestions.
