Morning all and happy new year, new this out of the way here is my question.
We want to convert our attached garage into a living space. The garage floor is 100mm lower than the inside floor, would it be possible to put a course of brick across the doorways (will have to have new shorter doors) and float a floor over the garage raft? if so would you need another DMP under it as technically it has already got one? Also again if possible at this depth would it have to be a wet floor or would 100mm screed be too much? Could I even reduce the amount of finish by adding insulation under the floor?
