Hi All,
We have a Servis M6755W washing machine that has developed a fault.
When you put it on to a programme, it locks the door and and starts the programme for about 10 seconds and then the light on the panel goes out and after about 5 minutes, the "End" light comes on.
e.g.
1. Put it on a spin and press Start
2. The pump runs for a few seconds and then stops
3. The light goes out on the display panel
4. A few minutes later the "End" light comes on
There is no drum movement through all of this
I've tested a circuit exists on the Element, pressure switch and motor.
Door lock works fine as it locks and releases.
My guess is the PCB.
I can get hold of a PCB at a reasonable price but have read that some PCB's need special programming/codes entered after installation. Is this true for this model or is a matter of plug it in and it just works? If codes are needed, where can I get them from?
Hope you can help,
Jonathan
e.g.
Hope you can help,
Jonathan
