One minute the down lighters were working and the next, nothing ?
Have traced the wiring from the down lighters to the bedroom wall switch and from there to the wall switch in the hallway where I found not 2 but 3 cables containing black and red wires (assume that the 3rd set is acting as a spur to the wall switch in the bedroom) There was also another single black wire leading from the wall switch in the hallway which was solely connected to an old unused baxi boiler thermostat. I believe that the problem has occurred when I removed the unused thermostat and disconnected the single black wire ???
Can someone tell me how the wiring should look at the switch in the hallway which now contains 3 blacks and 3 reds only ???
