I've got an old twin striplight fitting in a garage which wasn't working. I replaced the blown 1.25 amp fuse inside the fixture with a 3 amp one and now one of the 5 foot T12 tubes is working. I tried swapping them round to check it was the tube and not the circuit.
I read somewhere that you can't use the T8 replacement tubes if there is a Thorn SRS ballast in the fitting - which there is. Does anyone know why this is and if there is any other solution ? T12 tubes still appear to be available but only if you buy at least 4, which would make it cheaper to replace the fixture.
John
John
