Problem with Thorn Emi Housewarmer
11 Aug 2007
Hello to all.
After hours of searching on the web about info for a housewarmer system, this forum is my last chance to solve my problem.
i just i moved in, at a little od flat. It has got as a central heating system, an old one Thorn Emi Housewarmer Elegant 30/45.That device is fixed to tha wall. The problem is that the upper front knob, that probably adjust the time of heating, is missing. And therefore the heating works undesirable, since is very cold here and we need more heat.
Can anyone inform about how i can adjust it, and where I can found a manual of how this devil machine works??????????
Thank you in advance....
hello everyone
I'm a newbie looking for a bit of advice
My ex council house flat has an ancient and i believe obsolete
Thorn EMI Housewarmer II E 30/45 fire.
My ? is can i replace it with a current fire ( if so which one ) without changing the back boiler ?
les
No you're stuck with the lovely firefront
You've bought a museum piece - start saving for a new system.
If the wall thermostat is faulty its simple enough to replace.
