Hi all,
1st post here but I've been reading all about tiling etc so I wasn't too bewildered when I attempted to do my bathroom. But I have got 1 question with regards to tiling under the toilet.
Basically, the 12mm plywood and tiles will make the pipe that pumps water into the cistern is now too low and slight behind where the actual cistern pipe is - due to the offset pan connector pushing the toilet further out from waste pipe.
Surely everyone must hit this problem but I've not read it on here before? How do I get around this? I bought a 15mm flexible tap connectors which fits on the pipe coming from wall and bolts up, but won't fit the pipe from the cistern - I'm useless with plumbing things so I'm a bit stuck with it.
Any ideas where I buy a connector that will fit to both pipes?![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
