Problem with Toilet cistern/filling valve seal
18 Dec 2024
Hello, this is my first post so I hope I'm not breaking any rules by asking for help straight away.
If you want a summary of the below - basically the filling valve hole at the bottom of my cistern is leaking despite trying 2 new and different types of filling valve. I think the hole has somehow widened/warped.
A couple of days ago I noticed water leaking on the floor next to my toilet. I traced the problem to where the bottom of the toilet cistern meets the white plastic nut of the filling valve.
The filling valve was an old-fashioned ballcock type, of which I've replaced before, so I tried tightening the nut, and when that didn't work I took all the steps necessary to refit it (flush the cistern, bail out the water, and sponge the last bits, unscrew everything and refit). It didn't work, so I ordered a replacement ballcock filling valve off Amazon (a Delchem if that means anything).
Unfortunately, the one they supplied had a badly-machined nut which didn't screw up to the top; and various combinations of the old nut/old washer/new washer didn't resolve the problem.
After reading some posts on this forum, I decided to get a Fluidmaster filling valve instead and went to B&Q to get one. Fitting it seemed straightforward; BUT I still had the leak from the cistern. So I now suspect that the hole in the cistern is the problem. I shone a light under the cistern when the Fluidmaster was "fitted" and I could see light above, so I think the hole is too wide. I've tried cleaning it with a toothbrush as there was some debris from the old washer.
So what is the solution to this?
a) Get a bigger washer/adapater for the Fluidmaster (or the old ballcock valve)?
b) Buy some silicone sealant and seal around the washer?
c) Something else?
Thanks for any advice in advance.
Yes, the washer is on the Fluidmaster thread as per the instructions (cone down). But it's not keeping the leak out, and when I shine a light under the cistern, I can see it from above.
There was a lot of black debris (probably rubber from the old washer), which I've tried to remove with a toothbrush; and I've tried fitting again - actually fitted the old ballcock version and it did seem to be slightly less leaky, but nevertheless still leaked.
There's no cracking in the cistern, but the hole does look like it might be slightly warped; but not so much the washer shouldn't cover it.
Is silicone a permanent solution, or will I end up having this again in a year or so?
I had to take down the boards that were covering the pipes as they were soaked, and don't want to replace them if this can happen again.
Is the fluidmaster the one with a brass thread? It's the only one we use.
Get everything as clean and dry as you can, reassemble with a generous bed of silicone on face of cone shaped washer.
I would add a flat plastic washer between cistern and nut before tightening.
Is the cistern ceramic or plastic? You could try plumbers mait rather than silicone. Any photos of the problem?
