I have a problem with a Vaillant Ecotec 437. The boiler is connected to a large house one main header with a circuit feeding the ground floor rads, a circuit feeding the first and second floor rads and a flow and return feeding the underfloor heating. There is a pump on the GF circuit and a pump to serve the first and second floor circ, and a pump on the u/f heating manifold.
There seems to be a fault being shown on the boiler (I'm not exactly sure which fault code it was, could be F1), anyway the radiators are only getting luke warm, although a believe the rads at one point were nice and hot. If the boiler stat temp is turned right up to, say 70degC the boiler will run for a few seconds but then the temp will drop suddenly to say 40degC and dosent seem to rise back up again.
The pumps are working ok but the water isnt getting hot enough. The Vaillant guy has been out, he seemed to think the boiler was ok (but he didnt seem convincing). Could it be the way it has been piped up, or the position of the pumps perhaps, temp difference accross the header?
Has anyone come across this problem before on the Vaillant?
