- Joined
- 4 Jan 2007
- Messages
- 16
- Reaction score
- 0
- Country
Hi all , first post on this forum , have been a long time lurker , some great info and reading here . But now have a need to post . Be gentle
Some background .
My boiler is a Baxi105e . Its the only gas appliance in the house .
The CH works fine , always has . The stat calls for heat and the heat cometh.
The HW on the other hand is tempramental . We get about 15 seconds of hot water (but not so hot that you can't keep a hand under it , even with the boiler set to max) and then the gas cuts out . It then cuts back in , and then out again . Never reaching the original temp when first turned on . In the time I have been in this house , its never been right , although not as bad as it is now . The flow rate from the bath mixer is about 10l/min, under the boiler max I believe . The boiler itself has been serviced a couple of times , this problem was pointed out at both servicings but no solution was forthcoming , and had had the whole diverter valve replaced (not just the diaphram, although that appears to have failed again ( towel radiator getting warm when DHW running) .
Couple of other points .
-I get no fault lights blinking at all . the lights come on when they should and off when they should
-I live in a hard water area ( could the H/EX be scaled up ?)
-The HW control on the front of the boiler seems to have very little control over the output temp , but when turned all the way down there is no HW
I know its going to result in a Corgi Engineer call out , but if I could get an idea of what might actually be wrong it would be great
Cheers
John
Some background .
Cheers
John
