Hello Folks,
Looking for some help - but first the background.
Rad failed in living room and emptied water all over the place - of course this happened whilst I was away.....
Have replaced rad and filled succesfully - i.e water from bleed valve. Bled all other rads, fine. Water in f/e tank and feed pipe not blocked as all rads full also water at CH pump bleed screw.
Water in pipe below pump but seemingly no water in flow pipe from heat store to pump. Checked by loosening compression joint.
Any ideas how to remove what seems to be an airlock at the highest point with no apparent bleed point ?
All of the other boiler functions are ok h/w is fine, ch pump operates and creates head as no water escapes from ch pump screw when running - only when static.
How do I get rid of the airlock - if indeed that's what it is.
Thanks in anticipation...........
