Hi
i bought a wall tap on ebay quite some time ago and have only just got round to fitting it on.
this is the tap. http://cgi.ebay.co.uk/NEW-CONCEPT-W...LLER-W108_W0QQitemZ370150574950QQcmdZViewItem
the back of the tap has a threaded hole on either side.
i used one of these http://www.lbatech.com/var/62/8640-tb-UnionSS.jpg without the two end nuts and screwed it inro the hole at the back of the tap, and then joined this onto my pipework using a flexipipe.
the whole connection is fine except at the part where this part http://www.lbatech.com/var/62/8640-tb-UnionSS.jpg meets the hole at the back of the tap.
i have tried ptf tape and even tried putting an olive inside it but no matter what i do it still leaks. i got so fed that i even tried to stop the leak with solder.
what can i do? why is it leaking?
im at the end of my thether! please help!
