previous CH pump (oilfired CH) packed up after 8 years troublefree running. It was set on 3 (gather 2 setting is more usual). Plumber fitted new pump (Terrier TC5) bled system, pump on 3 (he said this is a slightly bigger pump) all ok for 48hrs. Then pump started an intermittent sceeching noise, quite loud. Plumber came back, bled pump, said it was air which had settled there. Problem has continued, I have bled rads several time and got some air each time from same rad. When pump is on there is a slight rattling like air passing through it and sometime a sort of echoy whooshing sound. Rads all heat up ok.
CH boiler is Danesmoor 15/19.
\Plumber did not do anything except change pump.
Any help would really be appreciated as he is now not answering his mobile.
The tech dept of the people who make the pump said symptoms were those of air getting into the system poss from pump not sealed properly. Plumber said if this were so water would leak out. Is this true?
HELP! I am a woman trying to cope whith this and give 100% care to my husband who is disabled. Can't cope without a warm house.
Thanks, anyone who can shed light on this.
