Hiya
Have been trying to fit a new front door only making it an interior as we now have a new porch.
As with many things in the house it seems the Original
front door frame was not put in properly
What i assume is a weather strip .........a strip of metal running along the bottom frame sticking up about 5mm is at an angle not straight with the frame. Found this after trying to work out why the door was not fitting in after making it true to the frame.
How easy is it to remove this strip or is there an easy way of cutting it without damaging the frame as it runs up to the edges so i can't see how i can get an angle grinder in without going into the frame as well.
The new door is hollow, having looked at the old solid wood door it had a strip of wood about 28mm along the bottom so it would close as it is 40mm width, the new door is 30mm.
Any idea welcome
Martin
Any idea welcome
Martin
