I have recently fitted an antique Victorian radiator in place of an existing modern single radiator in my central heating system. The problem is, it doesn't heat up. It came from a reputable dealer and was tested and fitted with new bushes before I got it. I can bleed the radiator, and do get warm water flowing through after a while, but it doesn't seem to find its way through to the return valve, although that is clear. The
The existing pipework is 8mm, and the radiator had a 1/2 inch BSP inlet and outlet. I have checked the pipework above and below the floor and it is not kinked or leaking.
The boiler (a Vokera combi) is fine and was recently serviced.
I have tried balancing the radiator system (there are another three radiators, of which this is the last), but cannot get it to heat up. Could it be that the 8mm pipework is not big enough to fill the radiator?
