My Indesit will not run the wash cycle and the control knob just rotates continually. I'm getting an error code of 8. Does anyone know what that code means?
Thanks for that information, so I guess the next question is how do you fix a 'stuck heater relay'? Does it require a new one or are they repairable?
Thanks for any further info.
http://www.emwelec.co.uk/index.php recon pcb from here ,you could try making sure the wires are tight on the pcb and give the relays a quick light tap on the board .
Where is the 'computer' board located? Removed the top, no obvious sign. The only other access points seem to be the back or the bottom.
Thanks for any guidance.
the w103 has a board down the rear of the mc bottom right looking from the front .if the drum has a clamp round the back of the drum its a evo 1 mc .if its welded tank board is still at the back but its a evo 2 mc .only thing on the console is a selector switch which clicks round to indicate a fault . are you sure its not a wil 103 that has a small pcb at the top but controlled by the bottom one.
