Hi, could someone in the know please advise on the following problem:
My Apollo Fanfare 50 gas boiler is controlled by a recently fitted Sunvic HW/CH programmer (to replace a faulty unit which had a broken display) along with HW and CH motorised valves and HW tank stat. On programmer demand it starts up ok but during running it continually switches on and off by an on/off electronic switching contact inside the boiler unit, generally it still runs ok but am concerned that this fault may get worse or burn out a switch or other controling device. I have checked the wiring connections to be ok. I believe that before the programmer was replaced the boiler ran ok.
Thank you
Thank you
