Problems with BAXI 105e
12 Oct 2011
Sussex
Evening all,
I have an 8 year old BAXI 105e boiler which is seriously playing up! When it's set to central heating and hot water, the heating doesn't work. Then when I run a hot tap, one of my radiators kicks in and heats up (the rest stay cold). The hot water works fine, but the boiler itself is making some very strange gurgling noises. Any help would be much appreciated. Thank-you.....
It sounds like a fault associated with the diverter valve.
What do you plan to do next?
Tony
GET THE BOILER SERVICED for a start. This will clear some defects.
Hi Tony, thank-you for your reply. I had my boiler serviced and it hasn't been the same since. Had the guy back and he said he had replaced the diverter valve. Had to get them out again as it didn't change the situation. So going to do a bit of research myself.
Obviously service was not done correctly then. Never known a situation where a service results in things going bad to worst. Some people do maintain 'if it aint broken, dont mend it' but in my book preventative maintanance as per the maker's instruction makes the appliance run better
turn off the flow and return under the boiler and see what happens far left and far right
then run then hot tap
The diverter valve costs about £100 which is a noticeable chunk of money.
Did that feature in your payments to him?
Wasn't it shown on the invoice?
Tony
