The story begins in an 1880s flat conversion in Richmond – my parents' home. I'm in the process of helping them sort out their bathroom, which has unfortunately been in a dire state for years.
Here's what's happened inside:
View media item 7979
The lime render has fallen off the brickwork, due to moisture build-up after showers.
Now, have a look at the exterior of this wall:
View media item 7981
As you can see at some point the wall was cement rendered without considering the obvious need for breathability.
This photo of the end of the wall may help identify the type of render used:
View media item 7982
We had the wall repainted a few years ago with some sort of exterior paint but it's bubbling at the base of the wall; further signs of trapped moisture?
View media item 7984
A local builder advised for the bathroom a sand & cement mix followed by a skim coat of 'Seeker' (sp?), which is supposed to be waterproof. All well and good but my concern is that by doing this any further moisture entering the wall (e.g. from the ground) won't be able to escape. I'm thinking it would be advisable therefore to chip off the exterior render and repoint, before decorating inside.
Further opinions please!
