I recently had my boiler stop working and discovered water had leaked into it and damaged the PCB. I fixed the leak in the ceiling and replaced the PCB but since then i have had a problem with the flames within the boiler.
When the boiler (Vaillant Combi Heater VCW T3W) kicks in, the flames do not just burn vertically but some "escape" and burn in the gap between where they should be and the outside wall of the boiler. These flames are then heating the boiler and the fumes are not escaping though the flue. After, for example, a shower there is an extremely noticeable smell in the house and the outside of the boiler is too hot to touch.
Does anyone know what could be causing the problem and what i can do to resolve the issue?
