OK, I have a prefab garage. The panels it's built from are 600mm wide with two vertical hollows, such that it has a thick vertical rib up the centre of each.
My plan is to fill the hollows with insulation, and attach a timber baton to each of the centre ribs. I'll then insulate the gap between the batons and panel over wit ply or OSB.
So, how to attach the batons? I suppose I could drill, plug and screw them, but I'm wary of damaging the concrete. There is steel reinforcement in the panels too and the garage is 19 panels long and 7 panels wide, so a lot to do!
Ideally I'd like to bond them in place, but of course I don't want my panelling to fall off in a few years. I plan to attach things to the panels too, so they'll need to bear some weight.
