HI Board!
I'm here to ask for your help, again.
OK, we've had our kitchen fitted and the tiler finished yesterday. He went to put the programmer for our CH back onto the wall bracket and as he does, the thing goes POP, trying to spot weld itself to our ring mains. Black Smoke Of Dead Elastrickery escaped from the gaps in the side and as much as i tried to scoop it up and push it back into the box, i could not.
So, no heating or hot water; 14 month old daughter and no electrician till at least tomorrow.
Now, I've had plans to change the Danfoss CP15 for some time as it's old and yellow and on top of the new tiles, it's awful.
I changed the fuse in the wall, threw the RCD off and put the CP15 back on the wall after cleaning the sooty contacts. It turns on and i can activate the relays calling for HW or CH, but nothing is happening.
Does this mean that the Programmer is not sending voltage to the Pump?
What should i check and in what order?
It's an open pumped system. Y valve with motor on top next to hot water tank in bedroom with cold water tank and F/E tank in loft and a Gloworm 30FF boiler.
Thanks guys.
Thanks guys.
