having just moved into a new house i have decided to replace my switchmaster programemer (that was falling off the wall).
i ve bought a drayton SM2 programmer, which also has a 24 timer, with on,off,once or twice setting for both HW and CH.
i was going to just change over the wiring for the relevant Live, Neutral, Earth 1,2,3 & 4 sockets, yet within my original unit, the CH off wire wasn\\\'t wired to 2 as label on the unit but strangely to the neutral?, yet the system still worked fine.
yet wiring the new programmer in the same way doesn\\\'t let the CH work off the timer (just on manual demand).
Thinking the original wiring was wrong i changed the CH off from the neutral back to number 2 as indicated on wiring diagram, yet this still doesn\\\'t allow the CH to work off the timer. just demand only!
can any suggest a solution as how to make the new unit work on the timer controls, or is the new programmer not compatable or even broken?
