programmer ?
25 Oct 2007
acl lifestyle model LP231,
I had a problem with boiler not kicking in when heating set to on. boiler comes on when hot water needed. I have had a new 3 way valve fitted , the stat is new. Now i only get heating when hot water is on. Is it the programmer? The system is fully pumped. The switch on the back of programmer is set to pumped. Programmer is 90s model.Sould I replace with new model? Somewhere on here I read a response to a similar prob and the answer given was the sycron on the motorised valve. Given my valve is brand new Im at a loss. Any suggestions?
You need to test the ch output from the programmer for 230V with a multimeter.
