proline pdw080
28 Feb 2007
Kent
Right I have the above dishwasher which has the problem that water was leaking into the underneath base which then i understand triggers some sort of overflow switch causing the pump to run constantly.
I know exactly what the problem is and it would be so easy to fix the only prob being working out what the part i want is called.
When you open the dishwaser door right at the very front is 2 grey little rubber pipes sticking up one at each side these are then connected to flexible hoses which drop down into the base. I presume they are overflows for if the water gets too high inside the dishwasher. Basically they have got chewed up and split so that water is going straight down them.
Now I even have got a diagram sent from comets spares but cant find them on it anywhere, surely you can buy something so simple?
Any help much apreciated
I cant find the part there anywhere either, maybe you cant buy it.
Thanks anyway
