Hi. Need some advice.
Above boiler worked well until some weeks back when it failed and would repeatedly switch to ignition lockout. On well founded advice requested a fixed price repair and an engineer duly came out diagnosed and replaced gas valve and boiler worked fine for a week thereafter. Now there is an occasional loud 'Bang' in the boiler [suspect this is explosive ignition] when it fires up again after having run for some time. First cold start seems to be quiet enough, but subsequent restarts frequently [not always] cause a loud unnerving 'Bang'. 'Bang' sound is even louder when heard outside below the Flue.
Prior to this recent failure - ignition lockout / gas valve replacement - the 'Bang' was fairly quiet and generally not noticeable. But this is no longer the case now.
Is this 'Bang' sound serious ?
And any suggestions on what could be causing it ?
Would appreciate your guidance. Thank you.
