semi detached property.
one of the rooms in my property goes through the party wall, so they have a room above mine.
the ceiling is only lath/plaster under joists with their floorboards sat directly ontop of the joists. nothing else is between.
i want to upgrade the ceiling.
2 hour fire resistance is 2x layers of fireboard and skim.
i also want to put in sound insulation.
i could suspend a new timber ceiling below the existing joists however im limited on head height.
if a new timber ceiling is suspended, whats the best way to sound insulate it?
is it rockwool sound insulation type over the top of the new suspended ceiling at 90 degrees, and then rocwool slabs between the joists of new suspended ceiling, with 2x layers of firebooards, or possibly 1x layer of soundboard and 1x layer of fireboard?
maybe use kingspan type rigid insulation?
or is another setup a better idea?
thanks
thanks
