Builders have been refurbishing my flat. As part of the work they had to rewire the entire flat, change the fuse box and lower the ceilings.
The fist thing they did was to remove the fuse box and fitted the false ceiling.
After re-plastering the flat, installing a new fuse box, fitting the lights etc, they suddenly announced that the flat never had an earth wire and fitted one by drilling a hole on the wall, running it below the gutters and screwing it to the electric box in the stairs. The flat has an external balcony, hence the wire is exposed to all weathers.
No other flats has earth wires running externally. They seem to run through metallic pipes and internally.
I need arguments to persuade the builders to find the original earth wire and do the work properly. I perceive their work to be hazardous and imagine that if there was a fire from my flat affecting the rest of the building the insurance company would make me liable for the damage. Are there building regulations to which I could refer?
Thank you in advance for your help.
