Can anyone advise please,
I have fitted:
Triton t80Z shower 8.5kw, 6mm cable to 45amp pull cord switch 8m run to Protec shower consumer unit 40amp RCD & 40 MCB then .5metre of 6mm cable to old style MK type 2 consumer unit, cannot get MCB for this unit as discontinued so run 6mm cable from drain plugs (i saw this solution elsewhere on this forum).
as soon as i switch on the shower it trips RCD, i have checked all connections they are all tight and as they should be, I have changed the shower unit but still the same, triton adviser told me it could be imbalanced neutral on the RCD. Not really sure what this means.
Any help would be appreciated thanks in advance.
I have fitted:
