Hi all,
I wondered if anyone can help me. I recently bought a house which has a radiator in the conservatory. It's an old style conservatory so the temperature drops quickly. I have sectioned off the kitchen (as doors were removed) using a heavy curtain. The kitchen now retains heat sufficiently. However I would like to avoid having to have the radiator in the conservatory on too much and waste gas.
I have had an idea to insulate the radiator in winter using layers of dust sheets and pipe insulation for the bits of pipe that protrude up through the floor. I plan on leaving the rad on frost protection so it will keep the system warm when the heating comes on. My heating is set to stay above 16 degrees as a minimum so it would be on regularly through the night.
Can anyone recommend what I propose, see any major drawbacks with it or have any alternative solution please.
Thanks in advance.
Thanks in advance.
